Cars & Trucks Logo
Lane Meche Posted on Apr 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2011 Mercury optimax. At 3500rpm alarm goes off and goes in guardian mode. Water pump and pressure good. Oil level is good. Oil pump working correctly. Changed internal pressure regulator. Any advice?
Level 3:
  • Mercury Master 19,187 Answers
  • Posted on Apr 27, 2018
Mercury Master
Level 3:
Answers
19187
Questions
0
Helped
4339030
Points
82259
This could be a lot of things. Have a computer scan done to see what the issue is. Could be a bad poppet or water pump. There is a sensor in the oil tank that can cause this too. Also the throttle sensor.
Testimonial: "Thanks for the info, I'll try these suggestions tomorrow!"
5 Related Answers
Anonymous
  • 962 Answers
  • Posted on Feb 06, 2009
SOURCE: oil light, noisy engine
What type of noise does it make. check if it has "blowby" . Blowby is when there is air coming through to the fuel system. It means that the rings , bearings , and other critical components are bad.The engine needs a complete overhaul or a new engine block. Maybe even the heads. if's it's a ticking, clicking kind of noise it is the valve lifters or rocker arm problem.such as the valves.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 08, 2009
SOURCE: Oil pressure gauge in 2003 Chev. Siverado
03 chev silverados have recall on instrument psnel for speedometer defefect. All onstruments were affected on my 03. Chk with dealer for recall time and mileage limitations to resolve. Good Luck
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on May 11, 2009
SOURCE: Low oil pressure light goes on until car warms up. Oil level is good
The oil pressure sending unit has gone bad. I sending unit is just above the oil filter and you can get to it from the top. When you face the Engine look down towards the oil filter, the oil pressure sending unit is just above that and it looks like a cylinder with two wires coming from it. If you don't see it, it's right between the exhaust manifold and oil filter.
If you go to Auto Zone or Parts Source, they'll have the oil pressure sending unit and the step by step instructions, When installing the new sensor. Do not use teflon tape or any sealant, the sensor is tapered and need's the good ground from the engine to give you right readings.
Good luck and hope this helps.
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on Jun 29, 2009
SOURCE: 1995 GMC Sierra z71 oil pressure dropped- need advice on this
The oil pump is in the oil pan and needs to be dropped and being a 4WD you also need to drop the front axle pumpkin to remove the oil pan and replace all the gasket needed. Start with the easy and replace the oil pressure sending unit, it's on the back of the engine to the passenger side of the distributor. You can go to Auto Zone and pick up a new Oil sending unit, just make sure your get the right one, "Sending Unit" Looks the same are the oil pressure sensor but the unit reads the pressure, the other just signal a light to go on and off. It's an easy fix like replacing a spark plug.
Anonymous
  • 1615 Answers
  • Posted on Jul 15, 2009
SOURCE: 1987 Chevy S10 TBI 4cyl 2.5 L will not run. I
Check the injector for 12v on one wire. if good check the other wire for a ground witth the key on. The ground wire pulses from the ECM If you dont have 12v from one wire to the other but you have 12v from one wire to battery ground then be sure the ground wire is good to the computer. If you don't have 12 v at any time check for open hot wire or bad fuse. ADD 12v to the hot wire at the injector. DO NOT add to the wrong wire or you will fry the computer
3answers
Alarm warning system on '02 Mercury Mariner 150HP E.F.I.-
Engine tank should be plumb full tight. The engine supplies about 2 lbs pressure through one of the 2 lines going to the boat tank. The other line takes the oil to the engine tank. If that line gets kinked or pinched, the engine tank won't get oil, a check valve lets a little air into it, and the oil pump keeps getting oil. When it goes down just a little, the alarm goes off telling you something is wrong.
Sludge in the boat tank could plug up the pickup screen. I've also seen them plugged up by a foil oil bottle seal carelessly dropped into the tank.
Once you find out why the oil couldn't get there, start the engine with the cowl off and loosen the cap on the engine oil tank until it leaks, then tighten it down and clean up the mess. That tank is normally plumb full tight.
If when the engine is running, you crack the cap on the boat tank, you should hear pressure let off. If the cap leaks, it won't build up pressure. If there is pressure, the oil line is plugged or kinked.
If pressure isn't supplied, the problem would be the crankcase check valve on the engine, lower forward starboard side, with the hose going to it.
hope it helps
2005 GMC envoy Oil pressure drops to zero when stopped if in a drive thru the car over heats. AC off its ok. Oil level/pressure fine replaced clutch fan wire harness(pigtail)replaced water pump.
The oil pressure drop indicates more problems.
Oil pressure drops to zero at idle on 2002 GMC Envoy after ...
www.fixya.com/cars/t7880379-oil_pressure_drops_zero_idle_2002_gmc Jan 18, 2011 - You could have three possable problems that I can think of. 1) Your oilviscosity is too low and you need to change it to a higher level. A 5w/30 .
Low oil gage and wont start1998 mercury mountaneer
check engine oil level sound like oil level very low.if oil level okay problem could be faulty oil pump or oil pump shaft to distributor broken or timing chain has lot of slack causing oil pump not to turn fast enough build up oil pressure or engine bearings worn out.
OIL LEAKING INTO THE SPARK PLUGS ON 2005 MALIBU CLASSIC
ENGINE OIL ISSUES/ OIL LEAK
The oil is getting leaked from its running area. The oil pump has to be pressure tested by pressure test to confirm the leak and area of leak: -----
For step by step troubleshooting check the help links mentioned below: -----
Click the link below: -----
Water in engine oil?
http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
High Oil Level on Dipstick
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Oil pouring out from left front of engine?
http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Kia Sportage leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
Toyota Corolla leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Overfilling oil in engine?
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
2000 Dodge Ram 3500 Cummins Diesel: Oil Leak issues?
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
HOW TO RESET OIL CHANGE INDICATOR?
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These details will help.
Thanks.
1helpful
Oil all over top of engine
Battery and Oil Warning Light Comes ON?
http://technoanswers.blogspot.in/2012/06/2003-chrysler-pt-cruiser-battery-and.html
Thanks.
Oil in the radiator
Thanks.
Oil in water
The oil is getting leaked from its running area.The oil pump has to be pressure tested by pressure test to confirm the leak and area of leak:-----
For step by step troubleshooting check the help links mentioned below:-----
Click the link below:-----
Thanks.
2helpful
4answers
Oil pressure warning light is buzzing and i've replaced the sensor on my 94 vw golf
Could be a few things, I assume you've checked the oil level. You could have a worn engine and therefore low oil pressure, could need a new oil pump. you can connect a mechanical oil guage to check whether it is a problem with your guage
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
