Exercise & Fitness Logo
Steve Bunten Posted on Apr 26, 2018
My NordicTrack T5.3 suddenly started making a very loud clunking noise that happens at any speed. It seems to be coming from the area of the motor. Any ideas what is causing it?
5 Related Answers
Anonymous
  • 64 Answers
  • Posted on Jul 16, 2008
SOURCE: Clunking and grinding noise
My 2003 F150 Supercrew would not engage in 4x4, it ended up being the shifting fork in the front end, cost me $200.
Anonymous
  • Posted on Mar 24, 2009
SOURCE: Loud clunking noise in front end over bumps
THIS IS THE REAR CONTROL ARM BUSHINGS THE BANGING IS THE CONTROL ARM HITTING THE K FRAME
Anonymous
  • 253 Answers
  • Posted on May 13, 2009
SOURCE: loud humming noise from front end of Durango 4 x 4
You have a hub/wheel bearing going out. You need to jack up the vehicle on each side. Grab the top and bottom of the wheel and try to move it in/out at the top and bottom. If this does not work then roll the wheel as fast as you can and see if you can hear which one it is. Good Luck.
Anonymous
  • Posted on Sep 07, 2009
SOURCE: hi there. i have a 1986 toyota hilux 3.0l turbo(knocking)
I have a Toyota Hilux 3.0 KZ-TE fitted with a intercooler and on Saterday on a 4x4 outing the engine light on the dashboard came on and the motor started spluttering and excessive white smoke came out of the exhaust. The problem persisted for several minutes and then went away. The verdict from other 4x4 owners was that the turbo needs an overall, I cannot understand this as it is fine again with no mechanical interferance.
Anonymous
  • 85 Answers
  • Posted on Feb 24, 2010
SOURCE: LOUD CLUNKING NOISE IN REAR WHEEL AREA WHEN TURNING LEFT
sounds like either a sway bar end link or shock, more towards the end link tho
2answers
2002 Honda Accord makes loud exhaust sounding noise
The O2 sensor could have come loose, also look around the area of the O2 sensor for any cracks in the pipe, look for black coloring on the pipe, this will indicate the leak area. As exhaust smoke is blackish and will coat the leaking area.
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 • Dryers
1helpful
1998 GMC JIMMY 4 WHEEL DRIVE, NOISE COMING FROM FRONT WHEEL AREA
it is the u joints on the front drive shaft ,i had the same problem and like too never found it!!!
Acura Integra '92 loud clunking when accelerating
you can check the wheels make sure there on tight and make sure you tie rods and wheel bearings are good
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Stopped spinning after making loud noise.
First check if the motor is lose, if ther touting is in place, if some bolt is lose, or if there is any broken part. You can see this at eyesight.
When washing machine vibrates in this way usually you need to replace thrust bearing, see this document and also this one here
If you insert right model number here you get exploded view and parts
1helpful
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
