SOURCE: We cannot hear a ring on incoming calls
Sounds like your system defaulted. Only a few phones ring at system default and you may not have those ports connected. First, you need to figure out which Comdial Impact system you have. The phone will work on a few different Comdial systems. Find the main box and get a model number from that. You'll have to tackle re-programming ringing yourself or pay a local company to do it. If you do it yourself you will need the "programming and installation" manual specific for your system. A "user guide" will be of no use to you. You can search the net for "Comdial Digitech, Impact & Impression Programming & Installation Manual" Next, I would suggest a UPS backup for your system so this does not happen again. Unless you have a large carded system with dozens of phones, your phones require less power than a typical computer so a UPS made for a computer will be fine. The system will default either when the system memory battery goes too low or I have seen a few cases where power fluctuations will cause it (like when the power goes on-off-on-off rapidly in a storm) either way a UPS system with surge protection will help.
SOURCE: No ringing tone or incoming call sounds.
You may also want to check to see if the do not disturb button has been pushed on the sets that are not ringing.To release do not disturb push the button again.
SOURCE: Answering blackberry with Plantronics ATT V521
I pull the battery from my blackberry and I can use the voice dialing again.
SOURCE: Centro GSM freezes on incoming calls
yeah the same thing happends to me ever scence i put it on my computer nad i just got it so yeh im pretty mad :[
