The problem started that the car didn't want to shift out of park on occasion. I would have to wiggle the lever and click it multiple times to engage (sometimes it would take up to 10 minutes). Then as it got worse it stopped going into park correctly and wouldn't release my key- I finally took the floor console off and found the broken plastic insert inside the lever.
SOURCE: When my 95 Dodge Neon
You need to free up your throttle pressure control cable linkage that sits above your shift cable linkage at the top of your transaxle on drivers side. I had the same problem from time to time, caused it to stay in lower gear longer, and shift down hard when slowing down. Happened more when I drove it a little harder as pushing gas pedal further down causes it to rotate, but then sticks & doesn't come back right a way. Free it up with penetrating lube first, then put a good coat of spray grease like white lithium after its moving freely again, and it should be problem free for a while. You may have to move some things to get at it. If you need a picture email ([email protected]), seeing how I can't seem to figure out how to send it from here.
SOURCE: Clutch pedal sometimes engages when near floor
Hi. Let me try to lend you a bit of assistance, also.
My fellow expert Benimur is very correct with his input to you.
But...Air does not get into your clutch hydraulics unless the fluid has leaked out at some point. As long as the cylinders and tubes are intact, I would doubt that air is the issue. Short of pulling the transaxle, and inspecting the clutch, there is really no other way to determine your issue properly.
Personally, I think that you haven internal problem with the clutch assembly. It could be worn fingers on the clutch plate, a worn clutch disc, or something as simple as the throwout bearing is hanging up on the input shaft collar.
If Beni's suggestions does not help, you are going to need to pull the trans off, and inspect the clutch items mentioned above.
Thanks for choosing FIxYa, we wish you the best of luck; let us know how it turns out.
SOURCE: 97 VW Golf Automatic wont start, battery fully charged
MY guess would be that it's the starter, with an automatic transmission, if the car is not in park or neutral, the car wont even attempt to start, so the clicking sound you say you hear rules that out. Now, im not an "expert" or anything just a guy with some general knowlege, so before you do anything i would recommend having it looked at, but if you feel confident enough, the starter is where i would begin, hope this helps, and good luck.
SOURCE: key locked in ignition... can't get it out. HELP!
while in park, press harder up past park and it will disengage. Otherwise there is a pin on the ignition you can press and remove the entire ignition. You call also lightly tap gently around igniton piece to loose the pins inside that hold the key.
SOURCE: 2002 Ford Escort: Shift lever stuck in Park position.
we do not have an escort but we are having the same prblem with our expedition...it is the break sensor switch near the petal and only about $13 dollars to repace. Easy plug,unplug instal
