Since your machine can do decorative stitches, I would think it can take a twin needle. Just BE SURE you have installed the needle plate with the wide hole for the needle and do NOT set a wider stitch than the twin needle can accommodate on it's widest setting without checking by turning the handwheel--the twin needle will overreach and either hit the presser foot or needle plate and sent needle shards flying!!! The manual should have instructions.
SOURCE: Can I replace the needle threader on a Pfaff 2056
It would be a two minute job for the Pfaff repair chap to do this....ring and check availability and ask for a quote, in our shop I would not charge to do this as you would be coming back for other goodies anyway, so it is just good business not to squeeze every last cent when word spreads of how reasonable and accommodation we were..
Phone and ask, save the stress.
Testimonial: "Thanks for your input - I'll call my local Pfaff dealer for a quote."
SOURCE: The bottom tension on my
check the top tension try a 3 or 4 but I wouldn't go any higher than 5
also put in a new needle
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
SOURCE: How do I remove the bobbin case basket on my Pfaff 2056
Perhaps the manual would be helpful (pg 2.9):
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwj4p9Sv3OnZAhUHLmMKHdQZAj4QFghAMAI&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2Fperformance_2056-manual-EN.pdf%3Fext%3D.pdf&usg=AOvVaw3YpszcCxsflKR0tdzy2CFx
It would be the opposite of the instructions for inserting the bobbin case. Pull the lever on the bobbin case and pull the bobbin case out.
