SOURCE: I have an LG dishwasher
Check your instruction book to see what the fault code OE lists as the fault
SOURCE: oe code on LG dishwasher following garbage disposal replacement
Well, there is the plastic block in the garbage disposal where the drain hose goes on (as not every disposal will be attached to a dishwasher). Punch this out with a screwdriver, fish the plastic plug out with your hand and reattach the hose. You are good to go.
SOURCE: lg oe
oe is a drain error not drain in 5min
The Drain Hose kinked or blocked.
Wiring connection is OK?
The drain outlet of sump is
blocked.
The Drain Pump/Motor or circuit is
troubled.
Remove the cause of kink or block.
Check the wiring connection.
Measure the electric resistance of
Drain Motor. (20-40 )
Replace the Drain Motor or repair
the Circuit.
SOURCE: LG dishwasher - stops washing
Hi there Romey. The error code OE relates to the drainage system, there are some things you can check to helpdiagnose the fault. you can check the filter in the bottom of the dishawaher isnt cloghed up or blocked. While you hae got the filter out have a look for any signs of large debrit that may cause a blockage. If all of this is ok you will need to check the waste pumps operational condition. make sure the pump impellar hasnt come loose/broken off or become jamed up.
If you cannot find any fault wit any of these things you may need to replace the control board. please let me know if there is anything else I can do to asist you with this issue.
Regards Gary
