Air conditioner thermostats are located at the front/top of the evaporator coil air inlet where they can monitor the air temperature coming back into the unit from the room
most are a small tube or bulb attached to the fins
Thank you Bill for the answer, however it did not help me because it did not address my specific model.
as explained --for the thermostat to work , it has to be in the incoming air flow so that room temp can be monitored
window box systems , split systems, car auto air conditioners , deducted air systems all have the thermostat in the incoming air flow( return air from the room) so the make and model would be immaterial if you know what you are looking for
Thank you Bill
SOURCE: Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
SOURCE: i need parts for everstar portable air conditioner
I have lost the exaust tube and the attachment that hooks up to the back of the unit to the tube. Where can I buy these parts?
SOURCE: The outside air temperature sensor for the 2003 Camry
the sensor is located in front of radiator if you open hood and look down behind front bumper you should see it, or look from under the frt bumper, it easy to change, also get part from dealer it not $$,hope this helps.
Testimonial: "Thanks-- I found it."
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
SOURCE: portable air conditioner not collecting water
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
