First thing you need to do is empty the water out so you can remove the clothes and do some trouble shooting.
The way to remove the water is to lift the flexible hose out of the discharge pipe at the wall and lower it into a bowl on the floor. You may have to raise the hose a few times to be able to empty the bowl. Once empty you should be able to open the door.
Its quite possible the pump is at fault and that should be your next move. Most machines have a flap at the front bottom corner to access the pump unit. Open the flap and remove the access to the pump. Take care to place a tray under for any water spillage. You should now be able to assess the situation. Not unusual for matchsticks/ hairgrips and even bra wires to be found.
Once clean replace the cover and rear hose and test the machine.
SOURCE: Our KitchenAid KAWS850LE1 Washing machine will not drain or spin
you need to replace the lid switch
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
SOURCE: Bosch Classixx 1000: Won't drain
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by
the machine during the softening cycle, so that the machine does not
completely fill the softening tray; only when the softening tray is
filled beyond the 'max' mark does the siphon action works. A partially
filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the
softening action is that the water inlet of the machine is partial
blocked (you can try to fix that) but it is simpler to just added more
water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every
time (after adding the softener to the softener tray of course) is to
top up the softener tray with extra water, top it up to the 'max level'
line (keep a bottle of water by the machine). That way, even if only a
little water is added to the softener tray during the softening cycle
by the machine it is enough to trigger the siphon action and the tray
will empty!
Works for me every time, and no need to remove any parts - I used to
take the tray out, clean it, scrub the outlet holes that fill the tray
etc, but they used to gum up again quite quickly!
Hope that helps
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
