Date on my navman is out by 2 months
SOURCE: setting date onCanon P23 DHV
I'm not positive because I pushed several buttons just trying to get it set and stay set -- but I think I did the following: fist push the "time set" button, ie the "memory plus" button then push the "format" button, ie the red "minus" button to change the settings -- continue until you have set the date and time -- then when you are finished you have to push the "time set" button, ie the "memory plus" button again to set it in place -- at least I think that's what I did
SOURCE: need to set the date and can't find manual--
Try this:
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
SOURCE: setting date and time
Turn the calculator on.
Hit the "C/CE" button and 0. will display.
Hit the "TIME" button so that the date displays.
Hit and hold "=" button until the month flashes. Now put in your date such as 11182008.
Hit the "TIME" button again so that the time displays.
Hit and hold "=" button until the time flashes. Now put in your time such as 1254. (12:54pm)
Hit "=" button to end.
SOURCE: date set
The winding stem of the caravelle has two positions when pulled outward from the case. Pulling it full out lets you set the time. And, by rotating the hands through successive twenty-four hour periods it resets the day of the week. Pulling the stem halfway out allows you to set the month, but only if you rotate the stem in a counterclockwise direction..
