Expert
- Posted on Feb 14, 2023
Re: My igloo model frw062 stoped cooling
If your igloo model frw062 has stopped cooling, there are a few possible reasons why this might be happening:
- The temperature control could be malfunctioning: If the temperature control is not working properly, it could be causing the refrigerator to run continuously and not cool properly.
- The condenser coils could be dirty: Over time, the condenser coils can become dirty, which can cause them to overheat and reduce the cooling efficiency of the refrigerator.
- The compressor could be failing: The compressor is responsible for compressing the refrigerant and pumping it through the system. If the compressor is failing, it may not be able to do its job effectively, which could result in poor cooling performance.
- The refrigerant could be leaking: If the refrigerant is leaking from the system, the refrigerator will not be able to cool properly.
To fix the issue, you may need to troubleshoot the refrigerator and try to determine the cause of the problem. If you are unable to identify the issue, it may be best to contact a professional for assistance.
