Kitchen Ranges Logo
Todd Monk Posted on Apr 24, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I broke a 6" probe off inside my FEF389WFCD electric range. IT IS NOT the Temperature sensor, it is attached to a bare copper wire and comes in through a hole between the light and the broiler.
I have called Frigidaire and numerous suppliers and nobody can tell me what this is. One thing to note, now that that is broken, my oven temp skyrockets in minutes and burns everything to charcoal. The copper wire comes out the back and up into the top of the stove where the buttons and display is. Help? What is this part? it looks like an easy fix if I could only find it.
Vernon Taylor
Level 3:
  • Frigidaire Master 7,446 Answers
  • Posted on Apr 24, 2018
 Vernon Taylor
Frigidaire Master
Level 3:
Answers
7446
Questions
0
Helped
1960331
Points
26207
You claim it isn't a temperature sensor, perhaps because there is a working temperature display? I don't know because I am not familiar with your appliance.
From your description I expect it is the thermostat thermocouple that is broken and the bare copper wire is actually a capillary tube. Normally a sealed assembly with the thermostat, when broken the thermostat doesn't shut down the oven.
  • 1 more comment
  • Todd Monk
    Todd Monk Apr 24, 2018
    Hi Vernon,
    Thanks for answering and shining a bit of a light on this.
    Upon further inspection it would appear that you are right.
    Thing is, that part doesn't appear on any of the schematics for my oven, which is baffling me.
    My oven has knob and electronic controls for oven but the knob seems almost aftermarket.
    Regardless, I need to replace it or the oven and I can't find this part on any part list for my oven.
    I am clearly over my head but this looks like an easy part swap, if I can find said part.
  • Todd Monk
    I am wondering if this thermostat only controls the functions for the knob?
  • Vernon Taylor Apr 24, 2018
    Chances are the oven thermostat was bought in by the oven manufacturer from a range of standard types. Similar to a fridge thermostat in form and function the typical oven thermostat consists of a bulb containing fluid permanently joined or part of a length of capillary tubing which is in turn permanently joined to the temperature control.
    The temperature increase in the oven turns the fluid to a vapour and a pressure builds and causes a bellows at the other end of the tube to push against a spring until the movement is sufficient to operate the electrical contacts. Adjusting the temperature varies the spring pressure.
    I suggest you search for thermostat. That the thermocouple is part of the assembly is taken for granted and often not even illustrated.
5 Related Answers
Anonymous
  • Posted on Dec 20, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Anonymous
  • 530 Answers
  • Posted on May 28, 2009
SOURCE: Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
Anonymous
  • 5911 Answers
  • Posted on Jan 21, 2010
SOURCE: Kenmore electric range: oven & broiler will not work.
All your oven features are controlled by the Electronic Range Control (ERC) board. This is your clock/timer assembly. Unfortunately, most do not have fuses and are not serviceable. You will probably need to replace the board. The following link explains how:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement circuit boards can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. For the model number you have listed, the part number for a new board is 316207511.
NOTE: The overlay, which is the plastic template with the numbers and letters preprinted on it, does not come with the new board. It has to be purchased seperately. However, if the current overly is still in good shape, it can be peeled off the old circuit board and reused. The part number (if required) is 316220841.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Anonymous
  • 43501 Answers
  • Posted on Mar 05, 2010
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Anonymous
  • 43501 Answers
  • Posted on Dec 11, 2010
SOURCE: Have a Tappan Electric Range
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
I own a Kenmore elite Model 790.4660 electric range. When I attempt to use the oven there is a beeping message "F30ERR" Thank you. Mark
Thank you for question. I understand your concern with your Frigidaire range. Without knowing the model number I can't be 100 percent certain but F30 generally implies an open oven temperature sensor probe. The oven temperature sensor probe is located inside the oven cavity in the rear upper left or rear upper right hand corner. It can generally be removed and disconnected from inside the oven cavity.
Check the wiring harness connections between the control board and the oven temperature sensor probe connector. Check the resistance or the sensor at room temperature with an Ohm meter, if less than 996 ohms, replace probe. Check with meter, for shorted probe harness between control & probe connector.
. I recommend calling a service technician to diagnose and repair your range.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services
tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
I have a ge profile electric stove,when i try to turn on the oven i get a f4 error.whats wrong
"F4" is a Oven Temperature Sensor error. This indicates that there may be corrosion on the termnal contacts of the oven probe causing poor contact, you may have a pinched or shorted wire on the probe, or the oven temperature sensor is defective and needs replaced. The following link explains how to access and/or replace an oven sensor on most ranges:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
UNPLUG the range and trace the wires on the oven probe with the back panel of the range removed. Make sure there are no signs of chaffing or bare wires that could be shorting out the probe. Disconnect the connector plug on the probe and check the contacts for corrosion as well. If you determine the probe to be defective, replace as necessary.
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
If you have any questions please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Error code f31 flashing
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore Gas range. Oven does not work and F30 alarm displays.
2helpful
I was the two front burners for an extended length of time yesterday on kenmore range. I got an F30 error code and the over will not work nor can I use the timer or the clock.
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is...
2helpful
Installed new EOC for Sears Kenmore Elite 790 46609500 oven.
I have a kenmore elite that has a f30 error can i fix this myself
1helpful
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
