SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
SOURCE: my john deere 316 stopped moving forward and
HAVE YOU CHECKED THE TRANSMISSION/HYDRAULIC
OIL? THEY ARE THE SAME. ON SOME TRACTORS THIS
CAN BE CHECKED AT THE REAR OF THE TRACTOR JUST
BELOW THE SEAT. IT COULD ALSO BE A BAD HYDRAULIC
PUMP.
SOURCE: I have a John Deere
probably a bad shifter switch you can order a new one here www.powerwheelsoutlet.com
