Sounds Like possibly the regulator is the issue.
Flightsystems Can test these to see if it is good or not.
also here is a link for the service manual
https://us.v-cdn.net/5020499/uploads/editor/0c/g1lx13xi2vyy.pdf
SOURCE: Yamaha ef1000 will only idle and produce 12 vac
Hi, I have the same generator and I pull the load and it is fine. The engine RPM is controlled by the
governor. The voltage will not come up until the RPM is at full. First see what the RPM problem is and then check the voltage. Open the cover and look to see if the carb linkage is hooked up , if it is you mite have carb problem and address that first. Hope that helps.
SOURCE: Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
SOURCE: 1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
SOURCE: Kohler 5E generator on my boat got wet there is no
If you fulfil these instructions and you need more help, please ask as an answer to this solution or on my e-mail: [email protected].
Please give some information about your generator: is it 5ECD, 5EKD or some other - then give some more details about it.
