SOURCE: larger clasp
Unfortunately, I do not think this is going to be an easy fix. You may want to take it to a local independent watchmaker. Gucci may sell larger clasps but they may be difficult to find even from them directly. I have looked at the watch you have. It it was solid gold a Jeweler could just make it a touch larger.
Looking at the clasps the options i see is
Have the bangle removed and wear it on a leather strap,
Possibly remove the clasp where it says gucci and have the pins laser welded so that the clasp stays in a fixed position similar to a bangle.
mike --consumerwatchguide.com
SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
SOURCE: The clasp keeps opening
Actually its alignment is off some time its fix & some time it's required to be replaced with new clasp, take it to watch repair shop
Hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
SOURCE: The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
