Ovens Logo
Posted on Apr 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miele oven model # H4780BP needs door hinge.What part # should I be getting?
mpservices
Level 2:
Wolfpack:
An expert that has 5 followers.
  • Miele Expert 191 Answers
  • Posted on Mar 03, 2019
mpservices
Miele Expert
Level 2:
Wolfpack:
Answers
191
Questions
0
Helped
245758
Points
342
Right hinge 4522671
Left hinge 4522661
5 Related Answers
Anonymous
  • Posted on Oct 13, 2009
SOURCE: thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
ashburton
  • 417 Answers
  • Posted on Oct 19, 2008
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
Anonymous
  • Posted on Nov 17, 2008
SOURCE: Miele oven door
I would be interested if you hear of a solution - I have the same problem.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 20, 2008
SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Anonymous
  • 3361 Answers
  • Posted on May 23, 2009
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
I have a Miele H 6560BP Oven. Took door off to clean glass and as removed the inner pane a metal lever on the door frame popped up and cannot get it back down to reinstall the glass.
The is the lever on the door that is the hinge part attached to the door and slots into the oven body?
Brute force and a big pair of channel lock pliers, or locking vice grips. It happened on my GE stove, I just wrapped it in a cloth and pulled.
https://www.google.com/search?q=Miele+H+6560BP+remove+door
May 27, 2022 • Miele Ovens
2answers
I have a Miele H4250B oven in which the door hinge is broken. I have the replacement part, but I am not sure how to remove the old hinge from the oven
I have the same model Miele and ordered a replacement part. I have 2 Miele ovens side by side, and a door hinge on both ovens began to malfunction. I ordered and received the hinge , but when I started to install it, I found that the hinges were fine! The issue was that the 3 screws that hold the hinges to the oven frame came loose. One of them had fallen out on each of the doors, they had to be jiggled in order to close properly, which was not satisfactory. The ovens were installed 13 years ago by the original owners.
You will need to slide the oven out of its enclosed space and unscrew the sheet metal siding in order to gain access so that you can unhook the coil spring attached to hinge. I found that one of the small machine screws has fallen out on the 2 malfunctioning hinges. Once the spring is unhooked, you can align the hinge to screw it back in, and tighten the other screws that hold the door hinges. The screws on the other side has also become loose.
Nov 29, 2020 • Miele Ovens
Hello. I need to completely remove oven door (side hinged) Miele H5681 bl. How do I get access to the side hinges?
https://www.manualslib.com/manual/103461/Miele-H-5681-Bp.html?page=63#manual
The above manual page shows how to remove the over door. I am not sure whether the video link below applies but have included it because it might be helpful.
https://www.youtube.com/watch?v=vYnRvgmGXAA
Oct 08, 2020 • Miele Ovens
How to take out miele oven door on model h6700bm
Open the door completely -
locate the latching locks at the hinge point
flip up the tabs on both hinges
Slowly close the door until you feel it hit the locking tabs
pull door upward and out to remove
Jan 28, 2019 • Miele Ovens
1helpful
Looking for door hinge for H4740b oven right side miele
Not an inexpensive part. Here's a link to someone selling it:
Miele H4740B Cooker Oven Hinge
Jan 03, 2018 • Miele Ovens
Heating element hangs down in Miele oven
Hi dose it look like something broke off on the top of the oven , usually they have a small bracket with a screw in it , do you even see a hole for a screw ?
3helpful
2answers
Loose handle on H4900B oven door. How do I access it to tighten the screws/nuts?
Look at your booklet that came with the oven - the page that shows you how to clean the door. The inside glass panel folds upwards and outwards and you can then access the screw holding the handle in place. Unfortunately you need a rather strange star-shaped screw driver.... I had to go and buy one but that's a lot cheaper than a Miele engineer call-out.
If you can't find your instructions you will be able to look it up online.
Catherine.
Door of Miele oven not closing properly
If it is a drop down door, the only permanent solution is to replace the door hinges, as it is weak springs that is causing the prob.
Hope this helps.
Thankyou.
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
2helpful
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Top Miele Ovens Experts
Paul Bade
vince
Are you a Miele Oven Expert? Answer questions, earn points and help others
