PAN8004W01C photo frame
With most devices you the two devices and treat the photo frame like an external hard drive. Open Explorer and copy/paste the pictures to the preferred folder on the hard drive. Then delete pictures it you want; don't cut/paste and lose all through a mishap.
I tried that with a USB to USB cable and the computer does not recognize the frame as an external drive.
It should, you might need to press F5 with Explore open to refresh the list of devices and maybe locate the frame. But if not, you can export the photos to a memory card, then use an adapter to insert memory card into a USB port on the computer.
SOURCE: I NEED A INSTRUCTION MANAL
I got my digital "pandigital frame last year and lost the instructions. Can you tell me how to download photos from my PC via Usb to frame?
thanks Deejohn2127
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
SOURCE: Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
SOURCE: Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
