SOURCE: gas cook top
Most of the time when I come out for a service call with this problem, it is usually because the burner cap is not seated properly on the base. Look at the burner and make sure there are no uneven gaps. Most of the time you will have to rotate the burner cap till a notch or pin "seats" into place. Most burner caps just sit on the bases, and so they get knocked off or moved when the cooktop is cleaned or installed. Hope this helps!
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
SOURCE: Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
SOURCE: 2 out of 4 burners working, left hand side with
heatman101
