to stop dogs barking you have to have the correct environment
they have to be able to see out of their area
they have to have companionship ( other dog as a play pal)
they need to be entertained ( toys )
finally there is a barking collar that can be obtained from a vet or pet shop
it is energized by the bark and gives a small shock to the throat of the dog
IT is effective and is not harmful to the animal and if not used when you are around to correct their behavior the mere fact that when it goes on they will, not bark
Hi I am a tech mechanic I deal with things like that Evey day lol but sounds like the anti theft or the ignition switch n lock n key to but you also have broke wires touching even in thecolom
your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.
Find an accredited shop that specialises in your vehicle and get on social media to see if there are anyone who uses this shop and how good they are. If you or any of your friends are in a motoring organisation then ask for a recommendation of the shop.. IF you have a V 6 and 2&4 cylinders are adjacent then it will be a head gasket . If not the head may be warped . A competent mechanic will be able you show you where the timing marks are pointing and if the timing is out by the marks not lining up. Forget the replacement engine as it was going and unless the engine was overheating before it stopped then the problem is fixable . IT is just a matter of getting the diagnosis right from a good mechanic.
