Question about Riccar Vacuums
My riccar 8955. If I lift it off the floor while it is running it shuts off. What's up?
  • Riccar Master
  • 1,603 Answers
Your 8955 could be as old as 18 yrs. Try tightening the screw holding the handle in, it could be loose allowing the handle to move back and forth enough to keep the switch from activating.
If it's an older vacuum or is used heavily it could have cracks in the body where the handle screw attaches or some damage inside the vacuum body where the handle bottom goes into.
If that doesn't help, Remove the bag door, remove the screws at the top to remove the cover to gain access to the area where the switch and wiring is located to inspect for the cause. When you push the lever at the top of the handle a lever going down activates the switch. It doesn't take much play in the handle to make the switch go on and off.
Posted on Apr 22, 2018
4 Suggested Answers
SOURCE:
  • 25 Answers
SOURCE: riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Posted on Mar 03, 2009
SOURCE: hello
buy a new one save your safe the time.
Posted on Feb 10, 2010
  • 694 Answers
SOURCE: absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
Posted on Aug 22, 2010
How to fix floor pedal on riccar 8850
Your 8850 is probably over 15 years old, almost all parts are interchangeable with the 8955 or 8925 model made today. You may need to replace the pedal if the catch has worn or broken. There is no wire on the. Pedal assembly but there is a spring that goes on the pedal shaft to make the pedal spring back after you push on it.
Oct 11, 2014 | Riccar Vacuums
How do I change a belt in a Riccar vacuum
Remove the screws holding the bottom plate on. Remove bottom plate. If it's an 8955 or model with clutch to shut off the brush roll remove the rod that goes from the lever to the clutch. Look closely how the rod and brush roll are positioned in the vacuum so you can reinstall it the same way. Remove the brush roll and install the new belt and then put back together as it was.
Apr 30, 2014 | Riccar 8955 Upright Vacuum
Power for riccar 1800
Start by checking the reset button on the back. It will shut the vacuum off if their is a clog or restriction somewhere.
Dec 14, 2013 | Riccar 8955 Upright Vacuum
Riccar 8955 quick cord release
Visit your local Riccar retailer
Nov 19, 2013 | Riccar 8955 Upright Vacuum
Brush will only run for a few seconds Riccar RAD.1
This repair should be performed by a qualified Riccar repair technician.
Oct 21, 2011 | Riccar 8955 Upright Vacuum
Remove and replace belt
Hi There,
Here's a very helpful repair that I did exactly for your problem on how to replace the belt on your Riccar. Your model, the 8955 is more difficult then other models due to the rug/floor selector knob. No worries though, I explained this step by step with pictures.
Hopefully this helps you,
http://www.fixya.com/support/t4373126-replace_belt_in_8850_model
Chris Jones
GoVacuum.com
May 02, 2010 | Riccar 8955 Upright Vacuum
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Where is riccar reset button>
The reset button on your model 8955 is in the back, on the left side at the bottom. It is a white button
Jan 15, 2010 | Riccar 8955 Upright Vacuum
Broke need replacement belt
You can get replacement belts for that model here:
Riccar 8955 Replacement Belts
Dec 02, 2009 | Riccar 8955 Upright Vacuum
Riccar 8955 sweeper won't run...where is thermal protection switc
Nov 24, 2008 | Riccar 8955 Upright Vacuum
Vacuums Logo
55 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
