The RoadPro Snack Master Deluxe typically includes a fuse in the plug to protect the device and your vehicle's electrical system. To access the fuse, follow these steps:
1. Unplug the Snack Master Deluxe from the 12-volt power source in your vehicle.
2. Inspect the plug. It usually has a cylindrical shape with a metal tip and a plastic body.
3. Look for a small cap or cover on the end of the plug. It may have a symbol indicating that it is removable.
4. Depending on the design of the plug, you may need to twist, unscrew, or gently pry off the cap or cover using a small tool or your fingers.
5. Once the cap or cover is removed, you should see the fuse inside. It will be a small, cylindrical component made of glass or plastic with metal ends.
6. Carefully remove the fuse by pulling it straight out from the plug.
7. Examine the fuse to see if it is blown. A blown fuse will have a broken filament or a visibly burned appearance.
8. If the fuse is blown, replace it with a new fuse of the same rating. Ensure that the replacement fuse matches the original specifications (ampere rating).
9. Once the new fuse is inserted, replace the cap or cover on the plug by aligning it properly and pressing it into place.
10. Plug the Snack Master Deluxe back into the 12-volt power source in your vehicle and test if it powers on.
If replacing the fuse doesn't resolve the issue and the Snack Master Deluxe still doesn't power on, there may be a problem with the device itself. In such cases, it is recommended to contact RoadPro customer support or refer to the product manual for further troubleshooting steps or to inquire about warranty service or repairs.
If it has a fused plug then the fuse has blown probably from more than 12 volts been attached to it. Replace the plug and reset the shut off and make sure that the power supply is 12 volts. If it does it again take it back for a warranty replacement unit.
Hi, I have an instruction manual for the Snackmaster jr Dehydrator by American Harvest model TD20. If you are still needing a copy of it, I can photo copy it and mail it to you. Please let me know.
Gloria
