SPL-TXC152A Shredder wont run Checked micre switches and power the circuit board has burn marks on it can i get parts
SOURCE: Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
SOURCE: Mr.
I found a way to do a fix that should last for awhile. Put the large gear in a vise leaving room to partially knock the small broken gear through. I used a bolt the same size as the hole in the plastic, and tapped it in about 1/4 inch. This pushes some of the small gear through, exposing more of the usable part of it. I then cut (hacksawed) off about 3/8 inch of the broken part, put it back together and it works!..................Good luck, Sparky
SOURCE: I HAVE A MODEL SPL-1506X PAPER SHREDDER, YOU HEAR
The optics are OK!
There is a small electromagnetic sensor on the cuttershaft which senses the input load.
I could be maladjusted or defective.
