I have a coolpix s570 and i just got a new battery for it because it wouldnt hold a charge anymore. now when i turn it on with the replacement battery the monitor turns on and when i hit a button, any button, the monitor freezes and i have to pull the battery to turn it off. how can i fix it?
The new battery may be really dead (discharged). Please leave battery out for a while and then put it back in and plug in the power plug. (Do NOT push any button on the camera) Make sure the camera CAN CHARGE the battery first. Typically one Green LED lights up and another one flashes. If it does this then WAIT until the battery is fully charged.
SOURCE: new nikon coolpix s570. sd card is not uploading
Use a good antivirus software to scan the SD card. Your SD card could be infected.
Hope this helped.
SOURCE: can i plug my nikon coolpix s570 into my computer
No. You must either remove the battery and charge it in the MH-63 charger or use a nikon coolpix s570. The best bet is to get a second spare battery so that you can recharge a spent battery.
Check
http://www.batteryengine.com/accessories/nikon_coolpix-s570_digital-camera_battery.htm
Please rate this solution. Thanks.
SOURCE: my nikon coolpix s570 keeps giving me a waring
The camera will turn itself off if it thinks the battery is too hot.
The manual just says to turn the camera off and allow the battery to cool down.
It is not right for this to keep happening.
If possible I would return the camer to the store and tell them about it, it may need a repair.
You may like to see if it is better with another battery.
Hope this help a bit.
Testimonial: "Thanks for your tips! I agree that it shouldn't be happening. Especially since the camera is brand new. I'm going to exchange it for a new one :)"
SOURCE: I have a NIKON COOLPIX
Hello
The problem is that the lens has become stuck in the barrel
after dropping it. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
SOURCE: Dear Expert, I have a Nikon coolpix S570 digital
Yes the possible solution is alright but there are errors within the camera. Sometimes the lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for spares.
