Question about Jacuzzi Home
How to fix Jacuzzi J335 with three dashes - Jacuzzi Home
    Top Expert:
  • Jacuzzi Master
  • 9,900 Answers
Recirculation pump not working replace
Posted on May 02, 2018
Testimonial: "Thanks for the advice, but pump was just replaced."
SOURCE:
How do I clear three dashes on Jacuzzi J300 series hot tub display?
either turn on pump or fix recirculation pump
Apr 21, 2018 | Jacuzzi Home
Jacuzzi has power but does not work panel has three bars instead of tempeture reading any suggestions
Those 3 bars usually indicate the circuit board is not working properly and will need to be replaced.
When you say has 3 bars this is what that shows. - - -
Sep 09, 2014 | Jacuzzi Home
How to pull off all three knobs from control panel
The knobs on the jacuzzi whirlpool pull off.
US Parts Center
May 30, 2014 | Jacuzzi Home
Does jacuzzi luxura have a built in timer
If your model has an electronic control then it will have a built it timer program.
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Mar 19, 2013 | Jacuzzi LXS6030 WRL 2HX A 60" x 30" Luxura...
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
Nov 26, 2010 | Leviton Timer Switch 2-5-10-15 Minutes, 4...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I purchased a very nice and expensive jacuzzi 60 X36 shower base in oyster and had it professionally instlled in new construction a little over three years ago. A week ago when using the shower I heard a...
some shower bases require additional support,I would call jacuzzi and explain the problem.If 6the unit required more bracing you will probably have to reach the contractor who put the unit in,then go from there,but this day and age it is hard to get satisfaction cause no one wants to be liable for labor and product.good luck hope you get satisfaction from one or the other!
Jan 25, 2010 | Jacuzzi T362-969 Tru-Level 42 X 36 Shower...
Jacuzzi luna plus will not come on lights or anthing this was a new install.never worked plumber skipped town has power to plugins
Thank you for posting your question here on Fixya.com.
Just because your installer skipped town, it is unlikely JACUZZI or the store you purchased the unit from is going to leave you high and dry. Try the retail outlet and if that won't work try JACUZZI direct for a warranty claim. Either way, you should be able to get the job completed without trying to tackle it yourself and possibly void future warranty coverage. You can reach JACUZZI at http://jacuzzi.com/resources/support.php
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 09, 2010 | Jacuzzi Luna, Whirlpool Plus -...
Do I have to clean my jacuzzi every day?
Just clean it once a week is fine.
Please rate!
Mar 17, 2009 | Whirlpool Home
Home Logo
157 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
