SOURCE: projection tv toshiba 43A9UE convergence problem
I would advise you to check the low values resistors around the convergency circuitry as well the fuse resistors and micro or pico fuses as well.
SOURCE: Linx Digital photo frame can't
Change the settings from the options !!
or edit the image be4 sending to frame !!
SOURCE: A/V cable for Vextra Photo Frame
Marvw50,
They mean one of these:
http://www.uuzip.com/6-Ft--Shielded-Cable--1-8--Plug-to-RCA-Plug_product_3897551.html
Very inexpensive...if you dont want to wait, im sure your local Radio Shack type store would have one in stock...but at a much higher cost :-)
Hope this helped,
Jem
SOURCE: acer aspire one stuck on windows safe mode restart
If you have the option of going to a command prompt (on the choose how to start "text" screen), do it, and type at the C:> fdisk /mbr then press the ENTER key. This may fix things. Also, try removing the battery when the computer is off, wait about a minute, then replace it and start computer. This actually helps sometimes.
SOURCE: 255w in a loop - loading maps, then restarts...can't recharge
Use a USB connection to your computer and let it charge for three hours. Also download updates while your at it. Cigarette lighter charger is not efficient
