Question about Pride Health & Beauty
Pride scooter fault manual
Blue light coming on after short use new batteries just fitted
    Top Expert:
  • Pride Master
  • 61,969 Answers
CHARGE THEM OVERNIGHT
Posted on Mar 06, 2019
SOURCE:
dromtonpa
  • 40 Answers
SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
Posted on Apr 03, 2009
my-mobility
  • 9 Answers
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
Posted on Jun 22, 2009
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
  • 175 Answers
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
hawk127311
  • 350 Answers
SOURCE: where and how do I replace my battery for my pride
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Posted on Feb 24, 2010
My mother-in-law's brand new pride mobility scooter, with full battery charge showing in the display, today would not go.
Hello, Liz -
Since your mother's scooter is new, you or she need to contact the seller of the scooter and ask your questions. No doubt it is still under warranty.
Best wishes.
Sep 22, 2018 | Pride Health & Beauty
Mobility scooter is unresponsive
.good mobility scooter
humm strange
...fitted a new throttle but still no go
any fuses in the system
might need a volt meter to test all the wires voltages and resistance between battery and throttle
info says comes with two batteries
ouch the w/55AH Batteries are about $250
are both batteries holding full charge
May 30, 2016 | Pride Mobility Products Hurricane PMV...
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
The status light does not come on.The batteries are new and the lights work .The running lights works,but the horn does'nt .
hi Edward, okay if you have no status light ? please verify that ? so no flashing light ?
Did you fit the batteries ? the reason I ask if someone else did it , did you see them fit the batteries because that fault can caused because the batteries have been fitted incorrectly then corrected however it done damage to the controller ....
it well be a wiring issue so check the wiring from the tiller to the frame to the controller, making sure there are no breaks any damaged of any sort ? please update me as I can help you ..
Regards
Rob
Sep 22, 2015 | Pride Mobility Revo 3 Wheel Electric...
Ststus light blinks 3 times what does that meanc
hi, well the error does depend on the controller used
if it's just three flashes ans a pause the following statement is correct however if it 's three flashes then it flashes again a different number of times then the fault is something else , can you please confirm this ?
the manual said
The motor has a short circuit to a battery connection.
Contact your service agent
"how accurate my answer is relies on you giving me the correct information"
Regards
Rob
www.gewizrepairs.co.uk
Jul 26, 2015 | Pride Celebrity Xl 4 Wheel Scooter
Hi moves foeward & reverse approx 6 feet stops dead ?
It can be any number of things.
1. Batteries are bad. Just because they are new, does not make them good or batteries you placed in the scooter are a lower (a.h.) than what is recommended by manufacturer.
2. short in the front/rear harness.
3. short in console.
4. park brake issue.
5. Thermal rollback.
It is an issue that a Technician should look at.
Aug 29, 2014 | Pride Mobility Hurricane Personal Mobility...
Green light flashing 9 times
sounds like you are sitting on some of the wiring or connectors, take it apart like you did to fit batteries and check there are no wires shorting out or connector is being squashed, check as you put it back together, you should sort it that way. the error code should be:
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
so check these wires and connectors closely first.
but please note that with out the make and model the error code is the most lightly posability.
Nov 26, 2013 | Pride Mobility Products Health & Beauty
Blue light on battery condition meter is blinking. It doesn't stop.
hi the blue light is indicating a fault, now count the flashes before a pause, or does it just flash all of the time ?
Please keep me updated.
Regards
Dec 22, 2012 | Pride Pursuit Xl Heavy Duty 4-wheel...
Set to move at 8 mph on full charge speed set to max only moving at 1 mph or less using battery charge in 20 mins
Hi, Sadly that sounds like your batteries have called it a day however please check your charger as this can have a fault and this can make your batteries appear weak and the battery teminal connections, are they loose ?. Check your manual as I think you can fit 12V 40Amp batteries to this scooter.
Please leave feedback if my advice helps.
Jan 17, 2011 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
85 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
