Restat?
stacked?
i have no idea these words? elaborate please .
tell what you do right and it does, wrong (a story)
my wild guess is the touch pad is failing
and no usb mouse attached,(hand held mouse)
that?
what OS is this , XP?
The mouse pad can be bad.
so can the mouse pad driver be corrupted , missing or wrong one installed.
start by telling the helper what OS,
click the (CP) control panel, click system'
the OS you run is presented to you there, in words.
windows what.
then CP (again, then click device manager)
under "Mice and other pointing devices."
see the mouse pad there, the driver there must not be
missing
or red or yellow marks ore UNKNOWN.
there are more tests and actions, but I stop here,
or get it repaired in a PC repair shop. (captain obvious sorry)
SOURCE: my laptop compaq 610 has problem nit's hang and
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jakauiay9
SOURCE: I have HP Compaq 610. Touchpad scroll was working
You will need to install the WIndows 7 drivers for your touchpad from HP. I have recently been on HP's site and find VERY few Win-7 drivers for any of the older machines.
SOURCE: i have compaq 610 laptop. my inbuilt webcam isnt working.
i am using windows 7 in my laptop compaq610 model webcam device is already installed but it is not networking.is any software to be used or what?
SOURCE: hi! I have compaq 610;
you probably have to change the current settings.
In most cases the settings for the mouse can be selected with the icon in the right of the taskbar, to the left of the clock.
It should have a setting for click on the touchpad.
If this option is not available, try the adjusting the settings from control panel >> Hardware and sound >> Mouse.
If it still does not work, try updating mouse drivers from manufacturers website.
Testimonial: "Thanks"
SOURCE: web not working for new compaq 610 laptop
i have compaq 610 laptop..i am using bluetooth to connect to the system using nokia pc suite...bluetooth is getting connected but the web cannot be connected .plz give solution
