Question about Sharp Refrigerators
The doors on my Sharp SJ-PT71R-HS refrigerator do not line up with the cabinet properly any more. How do I realign them?
SOURCE:
worldvet
  • 859 Answers
SOURCE: I have a 4 door
From my search the only Sharp Regrigerators are sold in Australia and NZ. Here's the list of spare parts outlets:
State Spare Parts Wholesalers Contact Details Queensland Prime Electronics- Bowen Hills
24 Campbell Street
Bowen Hills QLD 4006 Phone: 07 3252 7466
Fax....: 07 3252 2862
Email: mail@prime-electronics.com.au New South Wales Prime Electronics- Flemington
185 Parramatta Road
Flemington NSW 2140 Phone: 02 9704 9000
Fax....: 02 9746 1197
Email: mail@prime-electronics.com.au South Australia Statewide Appliance Spares
178 Sturt Street
Adelaide SA 5000 Phone: 08 8231 3369
Fax....: 08 8212 3195
Email: service@statewideapp.com.au Victoria Speedy Spares
451 Macaulay Road
Kensington Vic 3031 G.B. Telespares
5 Hunt Crescent
Clarinda Vic 3169
Phone: 03 9376 1333
Fax....: 03 9376 7110
Email : speedysales@bigpond.com Phone: 03 9512 7604
Fax....: 03 9512 7534
Western Australia WA Appliance Parts
135 Russell St
Morley WA 6062 WA Appliance Parts
1/9 Blaikie St
Myaree WA 6154
Phone: 08 92754755
Fax:...: 08 9275 4935
Email :parts@waapplianceparts.com.au Phone: 08 9330 1999
Fax:..: 08 9330 1677
Regards and hope this was Helpful,
Worldvet
Posted on Jun 02, 2008
woodchuck789
  • 4070 Answers
SOURCE: the left side door has dropped and the piece that
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Dec 11, 2009
burdfrenzy
  • 348 Answers
SOURCE: Our Sharp refrigerator model SJ-F60PC.
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Posted on Nov 26, 2010
heatman101
  • 43501 Answers
SOURCE: I have a sharp refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 27, 2011
panchal643Ja
  • 279 Answers
SOURCE: sharp SJ-F80SP-BK 4 Door refrigerator
SELF-DIAGNOSIS MODE
1. Entering method of the mode
1) Press the [Select] button on the LCD panel over 5 seconds at the opening condition of the
freezer and refrigerating room doors.
2) With a beep sound of buzzer, the self-diagnosis mode is entered. When the self-diagnosis
mode is not entered by the above operation, defect of Reed SW system can be considered.
2. When the self-diagnosis mode is entered, the following movements will be made. Forced release operation is not prepared for the self-diagnosis
mode. It returns to the normal movement after a lapse of 2 minutes.
• During the express ice making, express freezing or timer, the mode is released.
• Plasmacluster will not release the mode, and ON is forced for 2 minutes whether it is ON or OFF.
• When the self-diagnosis mode is entered, beep sound for reminding of closing the door must not be sounded for 20 minutes.
• Defect and various conditions are shown by the beeping buzzer pattern.
• Defect and various conditions are displayed on the LCD panel. In case of plural defects and various conditions, these are displayed one after
another by button operation and all contents are notified.
3. Display of self-diagnosis
• Display example of LCD panel (at the defect of F-thermistor system)
• Buzzer notice example; (at defrost defect, 2 times of 0.5 second ON)
Posted on Jan 12, 2016
Sharp SJ F60PC SL refrigerator-freezer is freezing the refrigerator compartment.
I would take a look to make sure your coils are not frozen or covered with ice on the inside of the fridge on the back wall and also double check the drain line on the back.
You could have a faulty switch that controls the thermostat as well.
Jan 17, 2018 | Sharp Refrigerators
We have sharp refrigerator. It has 4 doors. The upper refrigerator not working. The freezing down is O.K.
If you wish to get some details about refrigerator repair check the following link ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 03, 2017 | Sharp Refrigerators
How do I adjust the doors on a sharp sj-f60pc
You can open 3 Screw on top and adjust door.
Jan 17, 2015 | Sharp Refrigerators
Walter with bad semelhante in the back of refrigerador
Cooling is proper. If cooling is proper then drain line to be cleaned.
Dec 15, 2013 | Sharp Sj-K70mk2-Sl Top Mount Refrigerator...
Refrigerators Logo
74 people viewed this question
Top Sharp Refrigerators Experts
geob91
Elie Balas
Vernon Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
