Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valveb) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
The flush valve is the one attached to the water supply. The large rubber valve at bottom centre is actually called the flapper valve. I just wanted to make sure it was the flush valve you replaced. You should also know that the tank is not supposed to empty (so the seals don't dry out) but of course you should be getting a complete flush.
did you install the American Standard fluch valve with an OEM replacement or did you use a Fluidmaster replacement?
seal leaks and tank keeps refilling
