SOURCE: Water Filter
Look up to the upper right corner of the frige section and you will see a long white tube with a small latch on the end. Looks smaller than a Pringles can in diameter. Pop the latch down and the cover will lower. Hold the back as much you can and twist the filter about 1/4 turn counter clockwise and it should pop out. Once you install the new filter run a couple of "KoolAid" sized pitchers of water through the door to get all the air out of the line.
SOURCE: Amana refrigerator water dispenser
could be carbon particles from a broken carbon filter cartridge. replace the filter and flush about 5 gallons of water before checking the water again that comes out of the dispenser.
SOURCE: water leaking from bottom of side by side refrigerator
The is a fairly easy way if you have a strong stomach.
On the back of the refrigerator, you will see a plastic drain line running to a pan underneath the box. This is the drain line for the evaporator condensate water. It is stopped up in the refrigerator section of the box.
Here is the tough part...Pull the hose out of the back until you can wipe it off with a clean towel and blow hard through the hose with your mouth.
By the way ...take your food out of the fridge...you will blow some pretty disgusting stuff out of the drain and into your desert if you don't. This will cure your leak.
Pssst...you can used compressed air if you are a wuss! lol
Good luck
