I have been trying for over a week now to get past the google lock on my phone i reset it and i have a 2 step verifaction on my google account and no longer have the number and so on iv contacted google and they havent been much help and iv watched every vidoe there is and i always run into something im trying to do it on my computer now by downloading a bypass tool but i cant seem to find the right one or something can any one help please
SOURCE: Forgotten My Phone Lock Code
Please Goto a Sony-Ericsson Service Centre They will Sove It ...............................
SOURCE: my phone is locked and im trying to find a way to
You can try these methods of getting your phone unlocked:
1) Type 000000
2) Call this number - ##3282## then select "Advanced" and click "Ok" or "Menu", then select "Lock Code" and click "Ok" or "Menu" and then you can change the password to whatever you like!
3) Type in the last 4 digits of your phone number
If your problem persists, please don't hesitate to contact me on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Years Eve and please remember to rate this solution.
Warm regards,
BearWeb
SOURCE: i tried to sync my
i've got the same problem trying to synchronize my LG E900 with Outlook. Please tell me if you have found a solution
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset)
If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on.
Note: Factory reset will not remove the data and files that are in your phone's microSD card.
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
