Looking for help with the wiring. 14.5 hp engine has less wiring and cant find where to hook up the kill wire.
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
SOURCE: 1980 Honda Cm400a No spark
Hi and welcome to FixYa,
Bypassing the kill switch means removing the connection of the black / white wire either at the emergency stop switch (kill/run), ignition switch or preferably at the CDI connector.
Additionally, you can try:
Would appreciate a postback on results / updates.
Good luck and thank you for using FixYa.
SOURCE: electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
SOURCE: wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
SOURCE: I need a wiring diagram for a 28N777-1194-E1
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=28N777-1194-E1
There you go manuals diagrams the lot.
http://www.tulsaenginewarehouse.com/drawings/
http://www.tulsaenginewarehouse.com/drawings/allwiring.pdf
ALL wiring B&S engines above..
Testimonial: "Thanks for the links. Just exactly what I was looking for."
