I have a southland rear tine tiller, when in the lifted position, the tines spin, but as soon as it touches the ground, they stop. If i lift the tiller a bit they will till the ground, but only at about a half inch depth.
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
MAKE TWO PASSES SET THE DEPTH GUIDE SO IT JUST BREAKS THE GROUND, DON'T TRY TO DO IT ALL AT ONCE. SOON AS THE GROUND IS LOOSE IT WILL DIG MUCH BETTER.. IT SHOULD HAVE A FORWARD AND REVERSE FOR THE TINES, GEARS FOR FORWARD REVERSE DRIVE
Tines only spin in the T position.with cutch engaged.If thats not it split the case and check to see the shift fork operating properly. Or that chains are not broke. NOTE This is a serious job!!!
Hello, I think if you look at the depth setting bar you will find it clogged up with grass and roots. Once it clumps up you can't get it to drop to depth to make the cut. There are two speeds for the rear times for the toller which will make it go forward more slowly and allow the dirt clods to break up better. Also cut the grass as short as you can, make a shallow pass with the tiller 1" to 2 " to cut the heads off the roots and then go to depth with your next cut. This should pretty much break up the cloding when doing the tilling. Also watch it because it is hits a rock it will jump up and drag you away at the speed of the tines, because it lifts the drive wheels off the ground and the times drive the tiller instead. Other than that mine used to chew up everything including wet DG. Good Luck, RAC
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
