Panasonic Hi-Fi SA-AK58 5 Disc CD Changer AM / FM2
SOURCE: My panasonic SA-AK750 hi fi
Hi
The problem is mechanical, Disassembly carefully the section mechanism, clean all with isopropilic alcohol and grease again.
SOURCE: Panasonic SA-AK29 Disc Drawer won't stay closed.
It is quite possible that the timing within the mechanism had changed. Since the timing is quite important to activate the mode switch to triggerr the sequential action of the mechanism to proceed accordingly, a small change in any of the links can change the mode to keep away from resetting. Please open the set and check if there is any foreign particles lodged into the dirve mechanism. Clean and proceed. Check carefully for any sensors that are out of sync.If you are not sure do not attempt but try tomake a small correction to complete the loading so as the complete the mode. If so the fault might clear. Hope this helps you out.Good day
SOURCE: looking for a manual on
Here's the link for the online manual from Panasonic. Let me know if this is useful.
http://service.us.panasonic.com/OPERMANPDF/SAPM31.PDF
SOURCE: Hi, Can I buy
They are available from panasonic. I have replaced many. There is a skill level needed to work on one of these. You should get the service manual also.
SOURCE: Service manual for Panasonic SA-PM16
When I turn the machine off, it says, "Goodbye." Then five seconds later it turns itself back on again, including the EQ button. Is it doomed, or can I find a cure out there???
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=panasonic+SA-PT750
See "Play Mode" on Page 17
