What is the problem you faces with this TV? Provide more details please. If
you're sound in electronics, and wish to get more details, check this
link.http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Flip card, can be selected by the drop-down list, by the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name / model
number / IC used, in the search box at the top right of the display
window. google.com/+GopakumarGopalan
first open screw in backside and if you sure that all of them removed you can with thin card from the front you can begin to disassemble the cover.just you have to this job soft and carefully to don't damage the panel or monitor cover.
Your LG flatron resolution is
1366x768.. just change the settings on display properties at
1366x768, if there no available resolution, uninstall your display driver and reinstall your video driver, the process of driver installation detect your monitor resolution automatic <_>
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Have you tried to substitute a different cable? Many times a cable can go bad, and you cannot tell, because of how they are made. Get a different cable to try as a replacement, and see if that doesn't resolve this issue.
-a.
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
