SOURCE: Can't print from Adobe Acrobat
I was unable to print with adobe as well. I changed the document to print as an image under the advanced tab.
SOURCE: Adobe Reader 9 problem
I would like to help you to quickly solve this problem. Yes, you will need to install an add-on that will allow you to view PDF files in your FireFox browser. Follow these instructions.
1) Go to http://www.mozilla.com/en-US/.
2) On the navigation menu at the top, click on "Add-ons".
3) Next, in the text field where it says "search for add-ons", type "Adobe reader".
4) The add-on is named "PDFescape Extension".
5) Then click on the green button "add to firefox" located to the right of the add-on name.
6) A pop-up window will appear with the name of the add-on, in this case "PDFescape Extension".
7) Next you will see the "Install" button located at the bottom of this pop-up window, click it to install the add-on. After this, the pop-up window will close and open a install window.
8) In this download window, you will notice the progress of the download. When it is complete, you will be prompted to restart firefox. To do so, simply close the firefox browser window, and then start firefox up again.
9) To test the add-on, try viewing a pdf file in the firefox browser.
That's it!
I hope this helps. Please let me know if you have any questions.
Thank You,
Raphael
SOURCE: Can't print
if you have installed previously Microsoft Software Inventory Analyser, uninstall it, this solved my IE8 print, print preview and page setup problems,
Serkan Subasi
SOURCE: my printer prints out a blank page if im trying to
it sounds like your printer cannot translate the the graphics being sent from your computer.
It may be that one of your printer settings is not set correctly.
Or, it may be as simple a solution as updating your driver for your printer.
Try here for a driver for Laserjet P2055D:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3662055&taskId=135&prodTypeId=18972&prodSeriesId=3662052&lang=en&cc=us
If this is not your model, search for your specific model on this HP website.
Note there are also firmware upgrades for the P2055D printer.
Cheers,
Steve
