Question about Frigidaire Kitchen Ranges
Where is the plug located on a frigidaire electric coil range in the back? I know it says bottom left but is it in a cavity space of protruding?
SOURCE:
  • 334 Answers
SOURCE: Amana Electric range ART6510 had
You most likely pulled a wire loose when you were working on it.
Unplug the unit
Take the panel off and look for loose connections
Posted on Dec 04, 2008
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Posted on Dec 24, 2008
jumptrout51
  • 3361 Answers
SOURCE: Frigidaire smooth top electric stone eye stuck on high!
Yes,the switch controlling the burner is bad and must be replaced.
Posted on Oct 31, 2009
  • 949 Answers
SOURCE: my frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
Posted on May 17, 2010
dttech
  • 4803 Answers
SOURCE: need the diagram of coil pack and the order of the how the wires plug into it from top to bottom
Just thought I'd let you know, All you needed to say is "firing order diagram for a 1998 Pontiac Bonneville 3.8L engine". Here it is:
Posted on Jan 10, 2012
Does it have 2 plugs 110 and a 220
This is the oven spec, so it has to be 220 volts to support that wattage. The oven and broiler are electric and the hob is gas. Best of both worlds. (I am a chef)
Oven-Bake Element 2500 Watts
  • Oven-Broil Element 6 Pass 3400 Watts
    and then I found this :>)
    Power Power Supply Connection Location: Left Bottom Rear Gas Supply Connection Location: Right Bottom Rear LP Gas Conversion Kit: Included Voltage Rating: 240V / 208V / 60 Hz Connected Load kW Rating at 240/208 Volts: 3.7 / 2.8 Amps at 240 / 208 Volts: 15.4 /13.5 Minimum Circuit Required: 30 Amps
  • Frigidaire FGDS3065PF 30 Slide In Dual Fuel Range with 4 Gas Burners...
    Jan 31, 2016 | Frigidaire Gallery 30" Self-cleaning...
    How do I remove the bottom drawer of a frigidaire gallery electric range
    That's a great question, friend!
    I see you question is labeled under model FGES3065KB. In order to remove the drawer on that specific Frigidaire range you would need to follow these steps:
    1. Open the drawer to full position.
    2. Locate the latches on both sides of the drawer.
    3. Pull up on the left glide latch and push down on the right glide latch.
    4. Pull the drawer away from your range.
    I hope this information is helpful to you. -Matt
    Sep 10, 2014 | Frigidaire FGES3065KB Gallery 30" Slide In...
    Frigidaire crown series electric stove just delivered.
    Hello - I would first suggest confirming that the range is plug to the proper voltage (120/240 Volts 40/50 Amp). Was there anything located behind the range before pushing it back? From what you have described it sounds like the control board will need diagnosing. Contact a professional to move forward accurately.
    Oct 18, 2012 | Frigidaire FEF352 Electric Kitchen Range
    Oven does not heat, clock monitor register f2
    F2 fault code indicates the oven exceeded 590 degrees with the door unlocked. This could be caused by a stuck relay on the oven control board or it could be caused by high resistance in the oven temperature sensor probe.
    If the element will shut off then the likely failure is the oven temperature sensor probe. The sensor is located inside the oven cavity. It will be protruding from the rear panel in the upper left or upper right corner. The sensor can be removed and replaced from inside the oven cavity.
    Feb 11, 2011 | GE JBP66 Electric Kitchen Range
    We have a f10 error code on our electric range frigidaire es510l what does that mean
    F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
    Dec 15, 2009 | Frigidaire PLEF398AC Electric Kitchen...
    Location of Thermal Circuit Breaker, actually two
    located inside the back cover then remove rear access panel to oven cavity and they are there
    Sep 28, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
    What space is required behind range to allow for gas hook up
    If you follow the installation directions for this range, you should be able to have zero clearance from the wall IF the electric outlet and gas shut off valves are located in the proper places. The gas valve should not protrude more than 2" from the back wall in order to have the stove sit flush against the back wall, when pushed all the way in.
    Here's a copy of the installation instructions from Jenn-Air for your stove. Please see page 10 for their recommended location of the electric outlet and gas supply line and shut off valve
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P629-60.pdf
    Hope you find this Very Helpful and best regards!
    Aug 28, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
    Replace clock on range
    there is screw on back of range. remove screw and pull of back cover. that will expose clock. make sure you unplug unit first. don't forget where wires/plugs go
    Jun 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    MY FRIDIGIDAIRE FEF336BC BOTTOM COLI NOT WORKING
    F1 error is a bad control board. Replace the ERC, electronic range control.
    Mar 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
    Kitchen Ranges Logo
    60 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Marvin
    Marvin
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
