Computers & Internet Logo
A
ABDUL BAZIL Posted on Apr 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CE-00 ERROR REPORT WHITLE SCANNING TO NETOWRK FOLDER USING SHARP MX- M50 2N.PLEASE GIVE A CORRECT SOLUTION TO FIX THIS.
ALREADY CHECKED THE NETWORK CABLE CONNECTION .
Jeremy Keefer
Level 2:
Habit-Forming:
  • Expert 37 Answers
  • Posted on Apr 18, 2018
Jeremy Keefer
Expert
Level 2:
Habit-Forming:
Answers
37
Questions
0
Helped
29232
Points
118
You need make call to technical support.
4 Related Answers
Anonymous
  • Posted on Apr 20, 2009
SOURCE: Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Anonymous
  • Posted on May 17, 2010
SOURCE: mx-2300n network error ce-00 when trying to scan
Using Internet Browser access to the Printer/scanner, accessing Network settings, I noticed that the "Connection Test", (below the SMTP Settings), would not go through when SMTP Authentification was set to "ON". Turning it "OFF" allowed the connection test to succeed, but did not change the error code.
However, adding a secondary SMTP Server, allowed it to go through, (leaving SMTP Authentication set to "ON").
Good Luck
Anonymous
  • 33 Answers
  • Posted on Jul 20, 2010
SOURCE: Get network error ce-00 on the sharp mx-3501n when
CE-00 means ther is a bad destination entered or the copier is not seeing the server check the IP address
dwylie76
David Wylie
  • 82 Answers
  • Posted on Nov 16, 2011
SOURCE: keep getting a e-00 code on a sharp mx 2300n when trying to scan to file via network folder
The code is probably a CE-00 and it means that the copier doesn't detect a active network. Usually means the network cable is not plugged into the copier or the wall or the port in the wall is not active.
2answers
Keep getting a e-00 code on a sharp mx 2300n when trying to scan to file via network folder
Mx-2300n network error ce-00 when trying to scan to email?
Good Luck
Get network error ce-00 on the sharp mx-3501n when i try to scan to network.
Server unavailable error
Ah, the dreaded CE-00 and CE-02. This is a networking problem!!
It means the IP address stored in the copier for the computer you're trying to scan to is old and stale!!! That workstation got its IP refreshed by DHCP and your copier has been left in the dust!
To refresh the workstation's scan profile information in the copier either:
1) Reboot the workstation, or
2) Find the Network Scanner Tool icon in your tray, right-click on it, find Automatic Profile Update, and click on Update Now.
Also check the webpage and make sure that if you're using DNS for name resolution that you have the correct and working DNS IP's!!
4helpful
4answers
CE00 Error code
CE-00 means the copier cannot find the computer or server it's directed to scan to.
The usual cause is that the IP address for the scan destination has been changed by DHCP and the connection info has not been updated in the copier.
To resolve, reboot the destination workstation or server. Or, right-click on the Network Scanner Tool icon in the tray, select Automatic Profile Update, and click on Update Now.
If the scan profiles were created in the webpage and not through Sharpdesk/NST, make sure that destination names and/or IPs have not changed in the profile.
If you are using DNS name resolution instead of direct IP addressing, you must be sure that the DNS server IPs are correctly entered into the web page.
Hope this helps!!
1helpful
3answers
Regards Ed
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
