Hi Jimmy,
If I may suggest, before changing, please check that the inverter board is producing the necessary voltage to drive the backlights or not. If the board is producing the necessary power and still the backlight is not coming on, there is possibility that some of the LEDs in the backlight array have failed.
Testimonial: "No matter which HDMI input I use the screen is totally black again. The apple tv works fine on a different Vizio TV with a different HDMI cable."
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: VISIO E550i-B2
The main board of the tv is faulty. Can be a hardware fault or software error. You have to replace the mother board or can consult the service center.
of you wish to get some details about television repair then check the following link
Hey Matt, It was nice speaking with you on 6YA. If I can be of anymore help feel free to ask. Several other forums I browsed recommend replacing both the LED Driver and the Power Board at the same time and several say one at a time is fine. Replace the LED Driver board then go from there.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
hi the led in the panel may have shorted out thanks
shaun
Thanks Larry, I read that the power supply is a common issue. Any way to test this? Or suggest just replacing?
