Question about Frigidaire Kitchen Ranges
Just received a brand new Frigidaire Professional flat top stainless gas range. Light spots are appearing on the flat surface above the controls. They will not go away.
    Top Expert:
  • Frigidaire Master
  • 29,187 Answers
If it is stainless steel, clean with Flitz chrome and metal cleaner and then wipe with Baby Oil or Stainless Steel cleaner.
Posted on Apr 17, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Stains from cleaning products?
Bosch (BSH appliance care) do a stainless steel conditioner you could try. I think its called Starglanz.
Posted on Mar 29, 2008
reg501
Richard
  • 413 Answers
SOURCE: pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Posted on Jun 10, 2008
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
Anonymous
  • 5 Answers
SOURCE: Surface rust on GE Profile Stainless Steel Refrigerator
I would try a product called Evapo-Rust! Evapo-Rust will remove the rust without damaging the stainless steel finish on your refrigerator. After you remove the rust you will then want to apply a rust inhibitor to keep it from coming back. You can go to a website call http://www.rustremover.biz to learn more about Evapo-Rust. You will also find that they sell a water based rust inhibitor that will work to keep the rust from flashing back for up to 6-months.
Posted on Aug 02, 2009
Anonymous
SOURCE: I have a Whirlpool GS563LXSS
Hold the night light button for @ 3 seconds. It works for me.
Posted on Oct 21, 2009
Why did oven quit working and displayed F12 error?
Hey Renee, I understand that you are receiving an "F12" error message on your Frigidaire Gas Range. Before considering contacting a service provider, I would recommend resetting the range by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the washer to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 12, 2015 | Frigidaire FPGS3085KF Stainless Steel Gas...
Why won't the oven or the burners heat up on our brand new model CFEF3018LB range
Thank you for your inquiry, friend!
It could be a possible issue with the control panel or burner switches within the Frigidaire range. I would recommend performing a reset on your appliance which you can do by flipping the household circuit breaker off for ten minutes. It could also be an issue with your range not receiving sufficient power. You may want to seek assistance from a professional for proper repairs. -Matt
Oct 16, 2014 | Frigidaire Kitchen Ranges
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
Burners ignite but wont light
Are you on Natural Gas or LP?
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stains on the stove-top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Apr 11, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
