Please how can I fix error on a AT TRIUMPH ADLER DC 2118.. ERROR CODE :Alim off/on A 3200.
Thanks alot. It really worked for me, i mean the reseting procedure of menu>service sett>press #+start button+enter same time>enter 163>enter>go down to Execute>click start button. Then Restart machine. Wait a little so it adds toner then say 'ready to copy'. Hope somebody finds it helpful too
SOURCE: canon dc2018 fax machine -
Welcome to Fixya
C6400 Zero-cross signal error means:
While fuser heater ON/OFF control is performed, the zero-cross signal is not input within 3 s.
Try this troubleshooting procedure.
Turn off the machine. Open top toner cover. Turn machine back on. When you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Then scroll down to "maint mode"
press "enter" then enter 163 press" enter " turn off machine then turn back on and close toner cover.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: Triumph -Adler Dc 2020 with Error code c 710 please help?
Toner sensor problem or Developer problem
Description
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Causes
Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
