No brand or model? Okay, general reasons why grinders clog up. Most common I've found is worn out burrs. The plates, depends on composition and usage. Metal plates last longer but not forever. If your grinding thousand pounds of beans don't expect it to last. I've seen massive grinders fail within a month. It all depends on two factors; How much and how fine. Large grind size will increase life and fine grinds wear the burrs out very fast. Especially Turkish settings. Fine grinds also generate a lot of heat. This can cook the coffee again and make it change in flavor. Heat also forces the oils in the bean to coat the burrs and make them dull out which causes more heat. Prolong grinding will also burn out motor.
* Worse case senario; Very oily beans ground to espresso fine. This is usually the case with 'local' roasters. Poor quality beans, extreme roasting (pushing the max on toasting limits), and extreme fine grinds for a particular roast. Fine grinding tends to work on dryer beans. Heavy moisture (under roasted or beans not aged enough to outgas and dry out) will gum up any grinder. Let your roaster know what your trying to do. Otherwise go with a name brand and correct bean for the flavor profile your looking for. Don't expect 5 star espresso from a cheap roast.
* Final, most likely worn burrs needs to be changed out. Off chance the motor is burnt out or starter capacitor needs replacement. If it is the motor or cap, then you need to review your grinding methods as grinder motors are usually tough enough to handle the range of grinds listed in the specs. burning the motor is a clear sign of abuse.
* Have your vendor look at the grinder. They will know right away what's wrong.
Aloha, ukeboy57
SOURCE: Grinder
set the grinder to its courses setting.
there are 2 screws.
a rubber fitting is under the plastic compartment.
before moving anything. mark where that setting is. Then turn it until either the blue lines or the red lines are next to eachother.
you'll know you did it right because the top burr with come off easily.
Clean it out with a vac carefully.
slap it back on, turn back to the market setting and replace adjuster arm (be careful, it can break easily).
Should be good to go at that point.
I usually recommend it being brought in for service due to the grinder being extrodinarily pissy and you can accidentally knock it out of its shaft.
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
SOURCE: The V-Spresso burr grinder gums up using flavored
Hi
Its not a good idea to use flavored coffee in any grinder that will grind fine. They contain sugars and chemicals that will gum up all good grinders. Use an unflavored, preferably light roast cheap if you can get it. Set your grinder on very coarse ( largest number) and make a couple coffees. This is how to clean any good grinder. Once you have ground through the chea[p stuff. you can put you beans (not flavored) and use the 3 cup to drink. That way the cheap beans will not be used in your coffee. Don't put a lot of cheap beans in the grinder. A couple of handfuls is all that is needed.
Testimonial: "The solution was simple to understand and provided within minutes of posting. Thank you very much!"
SOURCE: My Jura S9's grinding unit clogged (due to Peete's beans)
Use the TABLET CLEANING. please refer to this manual here on page 24 if you don't have one.
Regards
SOURCE: Have a grinder and it
