Question about NorStar Lands Phones
Trying to remove incoming calls from ringing on a diff ext for a Meridian Norstar M7324. I have already confirmed extension is programmed as Appear Only under prog (Terminals & Sets, extension)
SOURCE:
SOURCE: No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Posted on Mar 12, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
Posted on Mar 23, 2009
ynotphone
  • 192 Answers
SOURCE: Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Posted on Apr 17, 2009
consultel1
  • 860 Answers
SOURCE: How do we remove an extension from a hunt group in
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool2.gif on.
Press the next key 6 times (bottom right arrow) .
The display should say System Prgrming.
Press the show key (top right arrow)
The display should say Hunt groups
The display should say Show Group:
Enter in the group number of the member that you wish to delete.
The display should say Member DNs:
The display should show members for that group.
Scroll to the member you wish to delete.
Press the Remove soft key.
Press the heading key(top Left arrow) till the display says Show Group: again.
Enter in the group number you wish to to change the deleted member to
The display should list the current members of that list
press the Add soft key.
enter in the DN of the member you wish to add
Select Appr & Ring setting for the hunt group member
Press the release key when finished
Posted on Oct 01, 2009
consultel1
  • 860 Answers
SOURCE: Incoming calls sound only on reception desk.
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Nov 02, 2009
Testimonial: "Great! Very specific and easy to follow instructions. Thanks for your fast response. RO"
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
How do I make one extension on my Norstar M7324 phone system ring?
Hi J,
Do you mean how to make it ring when someone calls a specific phone number, or when someone calls the specific extension?
If for a phone number, then you need the line to appear and ring on the phone. Let me know which one you're doing.
May 14, 2014 | NorStar M7324 Telephone
How do we remove an extension from a hunt group in a Norstar Meridian M7316 telephone?
Hi Marty,
Don't worry about counting your way through. Just log into the system, and you will see Terminals and Sets. Press next until you see System Programming, then press Show. Next until you see Hunt Groups, and press show. You can pick the hunt group you're changing and delete the extension from there.
If you're not seeing what we tell you you should see, double check the model of your phone.
May 14, 2014 | NorStar Meridian M7310 Phone
Our company has purchased a Nortel Norstar Meridian M7310 phone system, that has been previously used. We didn't know, but it did not come with voicemail, so it is tough to get calls when I am not here....
press the Chng key til it says appear and ring
Continue til all of your active lines say appear and ring
press the heading key(top left arrow) till the display asks for another extension number
repeat line programming for that extension
Aug 30, 2010 | NorStar Meridian M7310 Phone
Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
Jan 12, 2010 | NorStar M7100 Corded Phone
On my phone system (M7310) I only want one phone to ring when calls come in. currently 2 ring. how do I turn the other off?
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
Nov 10, 2009 | NorStar Meridian M7310 Phone
Nov 02, 2009 | NorStar T7316E Corded Phone
Old reception phone now regular office - reprogram
The display should say line 001: appear& ring
The display should say line 002: appear &ring
Oct 26, 2009 | NorStar M7324 Telephone
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
MERIDIAN M7324
Do you know how to program the system?
You will need to log into system programming. Got to lines/trunks and enter your extension. You will see the line appearances to appear only. You need to change those to appear and ring.
If you do not know how to get into programming. Call a professional.
Jan 07, 2008 | NorStar M7324 Telephone
Lands Phones Logo
122 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
