I'm not sure I understand what you are asking. The hose is not designed to pull the vac but if you pull and stretch the hose out and do something to restrict the airflow into the wand or hose it can pull the vacuum towards you or tip it over. It will only do this when the hose is stretched out because the suction is trying to pull the hose back to the vacuum but if it can't it will pull the vacuum towards the hose.
Let me try again: the extendable hose did not pull vacuum when not removed but only acted as a vacuum when pulled out...This has changed...Now the extendable wand, when seated in the machine, pulls vacuum (the hose becomes hard)...And is difficult to remove due to suction...This takes away from the floor vacuum, which causes sweeper not to pick-up...At the top of the hand held hose is a detent that the non-extended metal tube is supposed to seat in...Problem is the metal tube does not fully collapse...So when hand-held wand is seated in its not in use position vacuum does not shut off...
SOURCE: DC 17 Animal No suction on hand held hose
There is likely a blockage in the pipe. Try pushing something through taking care not to perforate the pipe.
SOURCE: MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
