Do you mean the Uniden DECT 1735? You can turn on the answering system from the base On/Off button. The rest takes the hanset or a call into the phone. Start with the phone in standby (no handsets in use). Press Menu on a handset. Use the Up/Down arrows to navigate to Answering Setup and press Menu again. To set the number of rings, navigate to Ring Time and press Menu again. Use the arrows to select a number of rings and press Menu to save. Press the Left arrow/Page key to go up to the Answering Setup menu. Press End to exit the menu system.
To set the greeting, you would navigate to Record Greeting in the Answering Setup menu. Press Menu. When you hear "Record Greeting", speak your message. Press Menu when you finish. Press End to save the message after you hear it repeated. Press Menu and wait for the "Record Greeting" prompt if you need to change the greeting.
The manual for this is available on the product site: https://www.uniden.com.au/product/dect-1735-2/. The direct link to the manual is currently https://www.uniden.com.au/wp-content/uploads/2017/06/DECT_17352_OM.pdf . See the section starting on page 20 for the different steps to set up the answering system.
I hope this helps.
SOURCE: We need a user manual for tevion D25AB big buttob dect cordless
manual for tevion d25 ab big button dect
SOURCE: Hi I've been trying to
Thanks for visiting FixYa!
Although you refer to the model number of your phone as a Dect 6.0 43-260 I've only been able to locate the instructions for a Dect 6.0 43-259. Hopefully, they are close enough.
This is a link to the Quick Start guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4300259_QS_EN.pdf
This is the link to the User Guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4300259_PM_EN.pdf
The User Guide explains how to record your own personal greeting as follows:
(See Page 50, Recording a Personal Greeting)
Your answering system comes with a pre-recorded outgoing message or
greeting that plays when you receive a call: "Hello, no one is available to take
your call. Please leave a message after the tone." You can record your own
personal outgoing greeting. Your recorded greeting must be between two
seconds and thirty seconds long.
1. On the base, press MENU/SELECT.
2. Select the ANS. SETUP menu, and then the RECORD GREETING sub-menu.
3. RECORD GREETING, START [SELECT] appears. Press MENU/SELECT
to start the recording. Begin recording after the announcement.
The message counter on the base LCD displays "30", and then begins
to count down.
4. When you finish recording, press MENU/SELECT again or press (key and LED (play/stop) . You
will hear a confirmation tone, and your recorded greeting plays back for you.
I hope this helps.
SOURCE: I would like to change
I had the same problem but couldn't figure it out either ..... UNTIL, I changed the date and time (which was very old, actually Sept/2007) to the current date, year, time, am/pm, etc.
After I changed the date, time, year, etc. my phone went back to its normal default of 3 or 4 rings & then the answering message plays.
Hope this helps!
SOURCE: I am looking for the
hello,kindly visit the site below to download your manual,
http://www.unical-estore.com/manual.html
www.nwbphones.com/faq.html
take.....care.
SOURCE: I want a downloadable main user guide for a MOTOROLA D1013 TRIO DECT CORDLESS ANSWER MACHINE PHONE
the d10 series are very similar. the link to the D1010 is the same as the D1013 (as far as I can tell)
http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/DECT%20D10-D11/Static%20Files/D1011%20Manual%20UK.pdf
Mik Carrington
