You just go to the link I attached I'm sure you will get the solution of your problem.
https://www.reliable-store.com/products/2014-jeep-patriot-service-repair-manual
SOURCE: code 7RR1.7
ive never seen one do that i cked it out and found out that your meter is bad i called scag for you thay said the meter is bad hope this helps
SOURCE: Scag SMT61A Mower with Kawasaki 27KA engine. 200
Look on the bottom of the fuel bowl. See if it has an electric fuel shut off solenoid. If it does unscrew the solenoid clean with Carburator cleaner and work the needle up and down until free. When you have it off of the carb plug it back in ground it to a metal surface and turn the key on and off. Watch the needle move up and down. Install back on Carburator bowl and start it up.
SOURCE: 14th kawasaki on scag. Fuel in crankcase
No idea what model you have but if it has a vacuum operated petcock, it is not shutting off properly.
You have the run and start wires backwards on the switch.
