MMMmmm user manual here:
Teac HDR2250T User Manual
(note: there are 2 manuals there)
And very odd... this "WHIRLPOOL" link has a lot of info on troubleshooting and you MAY have some luck there:
http://forums.whirlpool.net.au/archive/2372734
And THIS link mentions a "Firmware" update?
http://www.teac.com.au/support/product-downloads/eyJzZWFyY2hfbW9kZSI6ImFsbCIsInJlc3VsdF9wYWdlIjoic3VwcG9ydFwvcHJvZHVjdC1kb3dubG9hZHMiLCJjb2xsZWN0aW9uIjp7IjAiOiIxIn0sImNhdGVnb3J5IjoiMTIifQ
Also there appears to be a old 2010 FIXYA link with your model:
Questions Answers for teac hdr2500t
Otherwise, no luck on troubleshooting specific problems like yours? Sorry and wish I could offer better help!
Anthony
SOURCE: DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
SOURCE: Teac X1000R Reel to reel
Hi there. It will need a new pinch roller, and has a bias oscillator. problem. From memory, they use a module for the oscillator, and the pinch rollers are easy to get. Sorting out the bias may be the problematic part, and you will need to recalibrate the bias traps and controls if you want max performance from the unit once repaired. I would go about checking things like intermittent tape bias switch, and try wriggling the record play switch( internally) and see if you can get erase and rec back. Noisy intermittent switches can caused the symptoms you have.
If you are able to, I would be seeking a refund. If not, then repairs are feasible. Let me know where you are and I can help you find a repair guy. Cheers
regards
robotek
SOURCE: My Teac Z-7000 will not record tapes
some weeks ago I got this really impressive deck (Teac Z 7000) from a colleague, and found the same problem. I fixed it, and the fix is not too complicated. It´s the potentiometers that do fail. All pots are from the same manufacturer (Alps) and construction. The problem is that the wisher is broken away from the holding plastic and will loose contact completely. You can check that with a normal ohmmeter: You´ll find the total resistance over the outer terminals but endless resistance from one of the outer terminals to the middle wisher contact. The values are: 100 kOhm linear for each of the upper left pots (fader,space), 2x22kOhm pos.log. for the lower left pot (phone volume). So, what does a broken wisher at the "fade in" pot do? The Recorder "thinks" that You selected an "endless" fade in time, and the result is : no record level. You can do an easy "quick and dirty" fix just to see if that´s the problem: Hold- or better solder- a say 47kOhm resistor in parallel to the conducted potentiometer terminals and try to record.
4 of 5 pots have been defective in my deck, and I´ve replaced them with standard types from my local electronic supplier (Conrad electronic, has a shop in Frankfurt/Main). Well, the new parts didn´t fit perfectly, I used a file to get them in (not visible from outside). Also I lost the possibility of pushing the knobs in and out, but that is not a really problem.
I assume this fix might also help owners of the Teac Z-6000 and Z-5000, which- most probably- use the same type of potentiometers.
This text was written by Boris Witke, Kelsterbach (near Frankfurt/Main), Germany. E-Mail:
[email protected] Please tell me if You were successful, possibly we get lucky users of these really fascinating machines.
SOURCE: video records at high speed
You need to change your video settings. You have it set for time lapse. Turn your camera to the video mode on the top of the camera and then turn the dial on the back of the camera to the size of video you desire.
SOURCE: My TEAC 3340S (no, there
This deck was avail on base at the audio club while i was stationed in greece in 1971-1972, it cost $400.00, why are u fixing this?
This issue requires a Firmware upgrade contact TEAC Technical Support 1300 55 33 15
