This does not seem feasible, I have worn the device at night and not worn it at night. Turned the app on/off as well as my iPad. No change. I have been active over the period with with significant variations of heart rate, active or resting. Thanks for any tips.
SOURCE: the hearth rate only reads about half the actual?
Use this link to find out if you can get any help:
http://www.polar.fi/en/support/downloads?product=&category=User+manuals&document=/gip/PKBStoGIP.nsf/web_cat/C225742500419A8AC2256F4D003004C2 Unfortunately I can't fix anything unless I see it myself. All I can do over the internet is to give some advise.
Rate me, plz.
SOURCE: my heart rate monitor keeps stopping picking up my
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all POLAR watch manuals. Rate me, please.
SOURCE: Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
SOURCE: garmin edge 305 heart rate sensor does not work
the rescan worked for me, didn't know it existed, briljant. Follow list below:settings/system/accessoires/rescan
I love google today;o)
SOURCE: I have a Polar F11 Heart Rate Monitor. The watch
There is a step by step guide in my tips and tricks of things to try with your strap. If none of these work and you are getting a signal from another source then you need to get either a new strap, a new sender or both. If you send the T-31 wearlink into polar they can run a diagnostic and see which is bad and sell you just the piece you need or a whole new chest piece.
