SOURCE: olivetti lettera 25 typewriter
Re attach both ends of the string (drawband) and rewind the take up spring drum ther is probably a screw or somthing like it to rewind it
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
SOURCE: put back togather
http://img107.mytextgraphics.com/photolava/2007/11/23/mx5184-48lorgeqx.jpg
check out this link for the spring location
hope this helps :)
SOURCE: Poulan Wild Thing 18 Inch replace starter spring?
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
SOURCE: I have a craftsman model #968514 stapler. It
You can try going to www.managemylife.com. They should be able to help you. It is a Sears website.
