SOURCE: PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
SOURCE: archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
SOURCE: Archos 605 WiFi in Windows Media Player 11
just go to the settings and than formatting and than just delete the temp and that will solve your problem also try it on other computers
SOURCE: Xbox 360 Not Playing Music Through External Hard Drive
In windows media player 11, click on the small down arrow below library and select media sharing. Check the box for share my media then turn on you console. I dialog box will pop up asking you to approve file sharing. You can then customize your options for that device. If the dialog box dose not pop up you have a firewall problem. For the Iomega Media Drive, you have to use the software that came with it. Open the program click on configure, select the folders icon, and look next to your media folders and make sure DLNA is on otherwise your console cannot access those folders.
SOURCE: 605 not recognized by Windows Media Player 11.0
You may require a driver to work with your device. Try downloading driver from company's web site.
