SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode. PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
SOURCE: I have a Minolta cf3102 color copier. I pulled out
on the duplex unit is located on wright side .open the first outer door looks like 2 door in one .if you do not see any paper look for black actuator .in the center make sure it's not hanging up.
good lock
SOURCE: Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
SOURCE: Can i reset my Konica Minolta C250 transfer unit
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
SOURCE: WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
. Be sure to remove the waste toner bottle or you will turn the waste cap on your new transferbelt the wrong way and cause noise and image issues. Open right side cover, Remove 2 screws and slide locks out. Slide out transfer belt. Slide in new belt be sure not to touch the belt. Reinstall locks and screws. Transfer Unit comes with a transfer roller assembly that will snap in and out with two tabs.
